Activity Forums Adobe Premiere Pro How to select just the clips on the timeline that are to the right of the line?
  • How to select just the clips on the timeline that are to the right of the line?
    Posted by Bruce Mackown on December 27, 2013 at 8:35 am
    Is there any way to select only the audio and video clips that are to the right of the (vertical) line on the timeline? That way I could drag them to the right (or to the left) and make space to insert an additional clip (or eliminate space of a deleted clip). I’d make it alot easier to drop an additional clip right into the middle of what I’ve edited so far.
    Next question would be how to select just the clips that are to the left of the vertical line (what’s that line called that scrolls as the video plays on the timeline?)
    Jeff Pulera replied 12 years, 8 months ago 2 Members · 1 Reply
  • Jeff Pulera
    December 27, 2013 at 7:07 pm
    Hi Bruce,
    When dragging a new clip down to the timeline, hold the CTRL key and you can then “insert” the clip anywhere in the middle of things and all clips to the right will shift over automatically.
    To close a gap, right-click in the gap and delete. If deleting a clip in the middle, use Ripple-delete, or Mark In/Mark Out/Extract.
    Jeff Pulera
    Safe Harbor Computers
