Activity Forums VEGAS Pro How to select GPU to render with?
  • How to select GPU to render with?
    Posted by Jonas magnusson Magnusson on December 23, 2013 at 9:22 am
    I have two GPU:s in my computer, one GTX 670 and one GTX 460. How do I tell Sony Vegas Pro 12 to use my GTX 460 to render with?
  • When I have both GPU:s installed in my system Sony Vegas always uses the GTX 670 (Wich is worthless for rendering)
  • When I only have the GTX 460 installed in the system Vegas Pro will use that card for rendering and it only takes 1/3 of the rendering time it usually takes.
Jonas magnusson Magnusson replied 12 years, 8 months ago 3 Members · 4 Replies
    • John Rofrano
      December 23, 2013 at 3:51 pm
      Vegas Pro doesn’t specifically support two GPU’s so I’m assuming the software makes a CUDA call and the GPU that answers it is the one it uses. I’m further guessing that it’s using the Primary graphics card by default. Perhaps there is some way in Windows to tell it that your other graphics car is the primary card. This is just a guess but worth a try.
      ~jr
      http://www.johnrofrano.com
      http://www.vasst.com
    • Dave Osbun
      December 23, 2013 at 4:20 pm
      Your only option is to go into the Device Manager and disable the card you don’t want to ‘use’.
      Dave
    • Jonas magnusson Magnusson
      December 23, 2013 at 4:59 pm
      I will try that. 🙂
      December 24, 2013 at 3:12 pm
      Yes, this worked. Not the most convenient solution, but far better than nothing! 🙂
