Activity › Forums › Apple Final Cut Pro Legacy › How to see if clips have been moved/resized?
  • How to see if clips have been moved/resized?
    Posted by Bobby Hall on February 28, 2018 at 2:38 am
    Is there a way to see if any clips in a sequence have been adjusted in the Motion tab without having to double click them to see their Basic Motions settings? I’m curious since sometimes you can accidentally move a clip around and it would be convenient to see which clips this has happened to.
    Bobby Hall replied 8 years, 6 months ago 4 Members · 4 Replies
  • Shane Ross
    February 28, 2018 at 4:20 am
    If the files match the sequence settings, then you should have no render bar above the clip…so grey. BUT, if there is any motion adjusted, it’ll be green. SO, if you have clips that match the sequence settings and they have a green render bar above, they either have plugin, or some motion parameter applied.
    Shane
    Little Frog Post
  • Michael Gissing
    February 28, 2018 at 5:44 am
    If you have no clips that should have resize info, you can copy one clip that is correct and paste attributes ‘motion’ to all clips to make them all zero resize.
  • Nick Meyers
    March 1, 2018 at 6:53 am
    [Bobby Hall] “Is there a way to see if any clips in a sequence have been adjusted in the Motion tab without having to double click them to see their Basic Motions settings?”
    at the lower left of the timeline is a (very) small button with blue & green lines
    click this for “Clip Keyframes” view!
    it opens up anpther layer under your clips, where BLUE lines represent motion effects,
    and GREEN lines represent filters.
    keyframes are also included, and a great way to quickly move keyframes is in this view
    you can also toggle Clip Keyframes with Option T
    cheers,
    nick
  • Bobby Hall
    March 2, 2018 at 1:52 am
    Thanks for your replies, everyone. Very helpful!
