Activity › Forums › Apple Final Cut Pro Legacy › How to search markers in project window?
  • How to search markers in project window?
    Posted by Ariel Brener on December 3, 2009 at 8:31 am
    I want to search markers in all of my clips.
    I saw the option to search for markers on timeline
    but I want to search the entire project – there is gotta B a way – please help!
    ________٩(̾●̮̮̃̾•̃̾)۶________
    New Rig (Leopard 10.5.7):
    Final Cut Studio 3
    CPU: Core i7 920
    RAM: 12gig
    GPU: GTX 285 2GB OC
    HDD: 6 X 1 TB HDDs: 4 HDDs in RAID-5 and 2 HDDs for System.
    OLD RIG (Win Vista Ultimate 64bit):
    ADOBE MASTER COLLECTION CS4
    RAM: 8GB (Corsair 800Mhz)
    CPU: Intel Quad Core 2.4Ghz (Q6600)
    GPU: ATI x1950XT 256MB
    MB: Asus P5K Deluxe WiFi-AP
    Jerry Hofmann replied 16 years, 9 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    December 3, 2009 at 11:40 am
    Turn them to subclips. Then search. You can simply drag a marker in the browser window to any location and it turns into a subclip named the same as the marker was. The find command works then…
    Jerry
  • David Bogie
    December 3, 2009 at 3:52 pm
  • Ariel Brener
    December 3, 2009 at 4:24 pm
    This is my first project on FCP – Migrated from Premiere CS4
    Wow thats a major bummer…
    I have 20 hours of HD footage.
    Spread over many folders – and many many clips.
    inside of them I Marked more than hundred markers.
    Because I thought it will be very simple to search it up!
    I dont want to go all over the markers and make them as subclips it will take hours – and will create clips that I don’t want… just adds many Items in the projects…
    I can’t believe such a simple feature is missing! and the only markers that are searchable are markers which are shown and collapsed.. how stupid is that – I already see them – I want to search the ones that are hiding inside of folders and clips!!!
    How can I find all the quetes and notes I made to miself!?
    Final Cut Studio 3
    CPU: Core i7 920
    RAM: 12gig
    GPU: GTX 285 2GB OC
  • David Bogie
    December 4, 2009 at 3:00 pm
    It’s no that I don’t sympathize, I do. I see this topic often.
    FCP’s failures in metadata handling have been known since v1 and they could have been researched easily and thoroughly before you committed to a platform that, as it turns out, coes not support your preconceived workflow.
    You have two options:
    1. Change your workflow to accommodate the limitations of your platform (FCP has many more benefits than drawbacks)
    2. Obtain a third party application that helps handle your markers (CatDV and Cumulus are fully capable video catalogers with HUGE issues of their own)
    3. Just keep complaining.
    bogiesan
  • Jerry Hofmann
    December 6, 2009 at 12:07 pm
    It’s quite fast actually to drag a set of markers to a bin… you’d do this one time per clip with markers.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Ariel Brener
    December 8, 2009 at 7:42 am
    Thanks – about CatDV – does it integrate into the FCP interface – adding more ways to search my already added markers?
    can you please allborate more about this tool?
    I went to their Website – but didn’t understand how its working.
    Thanks anyway !
    you made me laugh!
    Final Cut Studio 3
    CPU: Core i7 920
    RAM: 12gig
    GPU: GTX 285 2GB OC
  • Ariel Brener
    December 8, 2009 at 7:45 am
    thanks I’ll try to play with it… but I have so many markeres spread on so many links – also what happens If the I add more markers to a clip?
    a
    Final Cut Studio 3
    CPU: Core i7 920
    RAM: 12gig
    GPU: GTX 285 2GB OC
  • Jerry Hofmann
    December 8, 2009 at 3:12 pm
    You can add markers any time to clips or subclips, then just create another subclip from that new marker… cmd+u is the keyboard command for it.
    Jerry
