Activity › Forums › Adobe After Effects › how to scale/zoom into an image till one pixel equals videosize
  • how to scale/zoom into an image till one pixel equals videosize
    Posted by Falk Messerschmidt on January 27, 2010 at 9:04 pm
    for a project I need to zoom into an image, till one pixel covers
    the whole size of the video. the problem so far, the issue is known
    here, is that the edges turn blurry since after effects uses an
    interpolation algorithm other than the “nearest neighbour” which
    would perfectly suite my needs. an easy work-around such as interpolating
    the image in PS isn’t working out since the image becomes to large
    – i’m getting the “image allocation buffer issue” error message
    which till that point i wasn’t able to solve.
    The draft method however results in a general shakiness of the image,
    the zoom isn’t smooth any more. I’m aware of the possibility to use several
    images lining them up etc., but is there no convenient way to realise that
    issue – i.e. to tell after effects to use another interpolation algorithm,
    or a third party plug-in that does the job?
    any help is appreciated. thanks in advance!
    Steve Roberts replied 16 years, 8 months ago 3 Members · 2 Replies
  • Todd Kopriva
    January 27, 2010 at 11:05 pm
    You can turn the layer to draft quality to prevent the interpolation/anti-aliasing.
    See “Layer image quality and subpixel positioning”.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Steve Roberts
    January 27, 2010 at 11:55 pm
    How about duping the layer, setting the upper one to draft, and animating its opacity from 0 to 100 as you zoom in?
