Activity Forums VEGAS Pro How to save video with exact same quality as original?
  • How to save video with exact same quality as original?
    Posted by Sergey Woropaew on October 22, 2018 at 4:43 pm
    i have avi video – every render i tried in Vegas makes its worse – it has crude quality (even if its same resolution and bitrate) or its darker or something else. Is there way to save video with same quality as original?
    Sergey Woropaew replied 7 years, 10 months ago 2 Members · 5 Replies
  • Graham Bernard
    October 22, 2018 at 6:30 pm
    [Sergey Woropaew] “Is there way to save video with same quality as original?”
    We need to know by a screen grab what you’ve ended up with. Also, your original material and just you’ve used to render. Oh yeah, your Project Settings.
    * Grazie
  • Sergey Woropaew
    October 23, 2018 at 7:27 am
    original is 640×480, avi, 1200 kb\s, 29 fps
    i render as –
    mainconcept mpeg 2 – dvd architect ntsc (640×480, 29 fps, DC coefficient 10 bit= so its max quality) – all background just black
    mainconcept avc (same specs as original) – just bad quality
  • Graham Bernard
    October 23, 2018 at 8:56 am
    That’s great. Thank you. You’re going to need to get busy with VEGAS Scopes and Level Adjustments/Correction for DVD. Somewhere along the line your blacks have got crushed and/or your Preview isn’t correctly set to show you your output. Have you burnt a test DVD and watched it on TV?
    Wrangling for renders and here, DVD, is a journey. ????
    HTH
    * Grazie
  • Sergey Woropaew
    October 23, 2018 at 11:51 am
    no i dont need to maked dvdd from it, i wanna just save part of this videio in original quality, and all of this renders of vegas just alters the video/ I need kinda like direct stream copy qualty from VirtualDub. Previews if right i did it all with mpc hc player
  • Sergey Woropaew
    October 23, 2018 at 2:44 pm
    ok i found how to resolve this – i set contrast to -129. but now skin color looks pale
