Activity › Forums › Avid Media Composer › How to rotate an image w/o BCC?
Posted by Olivier Prudhomme on November 5, 2014 at 11:35 pmThis week I work on MC 7 without BCC plug in.
How do I rotate an image?
Resize doesn’t have the rotate function…Thanks!!!
Job Ter burg replied 11 years, 2 months ago 6 Members · 14 Replies -
Juris Eksts
November 6, 2014 at 12:16 amIn the Blend section, you’ll find 3D Warp, that is your friend!
Glenn Sakatch
November 6, 2014 at 3:03 pmIf you already have some effects on your clips, you can promote some of them to 3d, which opens up a whole bunch of new controls.
Bottom right hand corner of your effects editor.
Glenn
Olivier Prudhomme
November 6, 2014 at 3:35 pmfor some reasons I always forget about this promote function
always have a hard time to find the button to click so, and then i move on. But i’ll try harder!
thx -
Brian Waz
July 13, 2015 at 6:13 pmWith the “upgrade” from V7.03 symphony to V8.03, I have lost the stock boris AVX plugins. Used them somewhat, especially the rotating on a graphic image. Yes, 3d works, but not the same when pushing in on a larger image. Pan & Scan really lacks this… any other options other than buying Boris?
Brian Waz
July 14, 2015 at 3:32 pmthe problem is that with MC7 you got the BCC package included, but on MC8, it’s not there and you’re forced to buy it to restore previous commercial projects. Not like it’s one or two items missing, it’s most of them. Avid, why bother putting any BCC in there?
https://i1.creativecow.net/u-upload.php?del=0_mc7tomc8.jpg#
Job Ter burg
July 14, 2015 at 4:21 pmSo if you had MC7 and BCC was included, that BCC plugin will still work if you upgrade to MC8.
The only time AVX compatibility was broken, was from AVX to AVX2 (a long time ago) and from MC5.5 to MC6 (from 32bit to 64bit).So again, if you had MC7 with BCC, an upgrade to MC8 will not make your BCC useless. You can keep BCC installed. You don’t have to upgrade your version of BCC when you upgrade your version of MC.
If you did not have BCC on v7, that’s another story, but your post suggested you did.
Not sure what your complaint is.
Brian Waz
July 14, 2015 at 6:32 pmComplaint… is I had BCC on V7 symphony, upgraded to V8 Symphony and told by the engineers that BCC was no longer included. I will quiz them again. Thanks
Michael Phillips
July 14, 2015 at 7:01 pmDo you not have your BCC installer from v7? That is what Job is referring to – it will keep working.
Michael
