Activity › Forums › Maxon Cinema 4D › How to rotate a torno w/o deforming it
  • How to rotate a torno w/o deforming it
    Posted by Andres Tupi on February 15, 2019 at 2:53 am
    Guys, I think it’s an easy one for you as experts. I am totally new at C4D and want to rotate a torno modeled using a spline. Initially, I modeled a spline expecting that my rotation axis was referenced in Y axis but after applying torno, I got a figure completely different, torned using X axis so I decided to model at first in X axis and then rotate it, however, I tried to rotate and only got a deformed torno. Please, tell me what I am doing wrong or how I should rotate the figure? Thanks in advance for any tip…
    Andres Tupi replied 7 years, 7 months ago 2 Members · 6 Replies
  • Brian Jones
    February 15, 2019 at 11:21 pm
    Tornado? Can you post your scene file?
  • Andres Tupi
    February 16, 2019 at 3:36 pm
    Hey Brian, thanks for your reply.
    This is what I wan to model…It’s a simple figure modeled with spline.
  • Brian Jones
    February 16, 2019 at 7:59 pm
    Lathe, I should have tried torno in google translate… it looks like you are rotating the spline object inside the lathe(torno) rather than rotating the lathe object itself.
  • Andres Tupi
    February 16, 2019 at 9:42 pm
    Brian thanks for your time.
    Dont get your point, sorry but my experience in C4d is really low. I selected the torno application (lathe) with spline as child and then rotate. I also selected spline and lathe, and then rotate, still same deformation. I think this is the question, how would you model this figure? Could list some steps to model the figure (red one) in the initial pic. Really appreciate your time.
  • Brian Jones
    February 17, 2019 at 1:21 am
    Without seeing what is happening it’s hard to tell. If you select the torno by itself it should move the spline with it and give you what you want. Do you have the axis tool activated? (It shouldn’t be). If all else fails you can just make it editable so it’s a poly object and not a torno anymore.
  • Andres Tupi
    February 19, 2019 at 7:39 pm
    thank u so much Sir! the problem was I had activated the axis icon. Finally have what I wanted. Have a good one!
