Activity Forums Apple Final Cut Pro How to roll trim on second video track?
  • How to roll trim on second video track?
    Posted by Sum Choi on December 28, 2012 at 8:14 am
    I have no problems roll trimming on the first video track but if I have a second video track on top of another, I only have the option to ripple trim and not the roll. Why is that?
    Don Smith replied 13 years, 9 months ago 3 Members · 4 Replies
  • David Eaks
    December 28, 2012 at 8:35 am
    One of the top results of a google search for “fcpx roll edit secondary”-
    https://forums.creativecow.net/thread/344/13660
    Basically you need to have both clips in a secondary storyline. Check out some of the many many free training videos for FCPX to get a handle on these basic operations, here’s a start- https://www.youtube.com/playlist?list=PL607BE2B2BFE9BE1A
  • David Eaks
    December 28, 2012 at 8:40 am
    Free training and the search bar are your friend. See at 6 minutes in…
    https://www.youtube.com/watch?v=VW8gwaGC-gw&list=PL607BE2B2BFE9BE1A&index=13
  • Sum Choi
    December 28, 2012 at 8:48 am
    Thanks. That solved my problem.
  • Don Smith
    December 29, 2012 at 11:56 am
    RE: “Why is that?”
    I suspect it is because the two clips aren’t part of the same secondary (connected) video track.
    Do they both have that ‘shelf’ that spans both clips and so both clips have ONE connection to the primary storyline? If not, then ‘bump’ one into the other by holding the ‘G’ key so that both clips have a common shelf. Now you can Roll the edit between the two clips.
    NewsVideo.com
