Activity › Forums › DaVinci Resolve › how to ripple color change to a whole reel
  • how to ripple color change to a whole reel
    Posted by Mika Joon on December 4, 2010 at 10:25 pm
    i’m trying to relative ripple a brightness change to a finished graded reel, how can I do this
    I’ve tried creating groups but they overwrite the look of some shots
    Gabriele Turchi replied 15 years, 8 months ago 6 Members · 8 Replies
  • 8 Replies
  • Rohit Gupta
    December 4, 2010 at 11:11 pm
    In the track mode, add a node, and apply the grade. The track node is applied after the clip node corrections.
    Regards,
    Rohit
  • Nate Weaver
    December 4, 2010 at 11:19 pm
    Just one node in the “track” portion (look next to “clip” in the nodes window) will do your whole timeline.
    I keep hearing about rippling changes to multiple clips in the manual, that sounds like they’re talking about something besides the ripple that happens in a created group. Does anybody know more about this?
    Specifically, in the “New in Resolve 7.0” section in the manual:
    “Color Control Enhancements:
    -Apply a ripple by adding a node to the end of node graph
    Automatically ripple a grade to any number of clips by adding a node to the end of each clips’s node graph with the ripple grade”
    Nate Weaver
    Director/D.P., Los Angeles
    https://www.nateweaver.net
  • Mika Joon
    December 4, 2010 at 11:26 pm
    thanks again Rohit
    how can I set a range of shots to do this to , lets say to just 1 scene
  • Gareth Cook
    December 5, 2010 at 2:51 am
    You may not want to use track mode as it use to not color trace, it might color trace now but you should check before you go down this road.
    Gareth
  • Blase Theodore
    December 5, 2010 at 4:26 am
    Hey Rohit,
    I’d like to be able to select multiple shots by command-clicking them, and add an adjustment node to them somehow.
    Is this possible?
  • Nate Weaver
    December 6, 2010 at 9:32 pm
    I’d hate to see this just die…?
    I’ve been reading some of the same sections of the manual over and over and it seems there’s references to ways of doing this, but no info…
    …which is bringing me to the one of the most popular questions of late, is this a full panel thing?
    Nate Weaver
  • Rohit Gupta
    December 6, 2010 at 10:31 pm
    Hi Nate,
    Currently this is available on the BMD and 2K (Linux) panels only. You need to enter , “Ripple value”. You can also enter -,+ “Ripple Value” as a shortcut for rippling to the entire sequence.
    We’re working on making this feature accessible to all users.
    Regards,
    Rohit
  • Gabriele Turchi
    January 29, 2011 at 6:31 am
    Hi rohit ,
    i do have the Davinci Panel ,and i can;t find any documentation about this keys combination like
    -,+ripple value
    Does exist any resources to learn this kind of combination ?
    For example ? is it possible that there is no button for Apply a grade from a still ?
    g
