Activity › Forums › Adobe After Effects › How to rewind a movie 1 second and then go forward again?
  • Ryan Hill
    November 17, 2009 at 8:26 pm
    Time remapping, of course.
    But I also only figured out the easiest way to do this from something I learned here. If you right-click on a keyframe you have the option to “select all keyframes to the right.”
    So you add two keyframes, one second apart, for a start point and end point. Then you can use the above trick, and the ctrl-click unselect to select the start point and any keyframes to the right, (but unselect the end point) and move them as a unit, until your start point is after your end point. By moving them as a unit, you make sure the speed goes back to normal after your rewind.
