Activity Forums VEGAS Pro How to Restore Faded Filmstock Using Sony Vegas?
  • How to Restore Faded Filmstock Using Sony Vegas?
    Posted by Benjamin Edge on September 1, 2015 at 6:24 am
    Does anyone what kind of plugins I would use in order to restore a faded red print of one of my favorite cartoons?
    I am referring to those films originally mastered to Eastmancolor film stock. These were notorious for being so red over the years.
    I thank you for any suggestions you may have in advance.
    ~Ben
    Bob Peterson replied 11 years ago 3 Members · 4 Replies
  • Steve Rhoden
    September 1, 2015 at 7:52 am
    Dont just be thinking plugins, you can achieve this by the use of
    Color Correction, which can be done within Vegas itself. Start with
    that first, there is no one plugin that’s gonna magically makes
    the clip looks better.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Steve Rhoden
    September 1, 2015 at 1:02 pm
    Just remembered, here is a very good free correction plugin you
    can experiment with:
    https://code.google.com/p/colorlab/downloads/list
  • Bob Peterson
    September 1, 2015 at 10:34 pm
    I would use Color Curves to remove a reddish caste. To do that, very slightly increase the colors blue and green. Make the increase in both colors at the center point of the curve. Do not adjust the end points since color fades away as you approach black or white (i.e. the curve end points). Blue and green mix to produce the color cyan. Cyan reduces the color red. So that increasing blue and green makes the color less red. However, the increases also brighten the image somewhat. To offset the increase in brightness, reduce the color red in the same place and by the same amount. I suspect that the adjustment needed will be fairly small.
    You select colors by using the “Channel” in the Color Curve screen. The default is RGB, but you can also select red, green, or blue.
  • Bob Peterson
    September 1, 2015 at 10:37 pm
    Oops! Wrong thread.
