Activity Forums Blackmagic Design Fusion How to Resize image in BlackMagic Fusion 8
  • Simon Ubsdell
    December 29, 2016 at 11:27 am
    The scale of your comp (i.e frame size) at any one time is determined by the background image. In that sense Fusion is completely unlike Ae.
    Without seeing more of your flow I can’t say what’s gone wrong here, but that is the answer to your question.
    Maybe post your composition here so we can advise more specifically?
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Mattie Trevor
    December 29, 2016 at 2:35 pm
    Thanks for the replay sir. but i think u didnit seen my attached image (link of the image i uploaded ) if u want to see my workflow for more details about my problem.
  • Simon Ubsdell
    December 29, 2016 at 2:49 pm
    Yes, I saw the framegrab, thanks.
    Without knowing the frame sizes of your background and your foreground images and your desired output image I can’t be more precise.
    From what I can see your background image is 1024×520, is that right?
    What is the frame size of your foreground image?
    What is the frame size or your final output?
    Thanks.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Simon Ubsdell
    December 29, 2016 at 2:54 pm
    Oh, and what are you doing with your transform?
    You will find it a lot less confusing if you use the transform options on the Merge node.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Simon Ubsdell
    December 29, 2016 at 8:28 pm
    I notice that I have already answered this question at some length on this forum:
    https://forums.creativecow.net/readpost/391/79
    Hope that helps.
    But please let me know if you need any further guidance.
    Simon Ubsdell
    tokyo productions
    hawaiki
