Activity › Forums › Boris FX Particle Illusion › how to resize height and width?
  • how to resize height and width?
    Posted by Avery Henderson on August 19, 2008 at 11:27 pm
    I was watching the Tutorial on creating the orb effect and I was doing everything right up until he said resize the height and width then the value thing popped up and I have no idea how to resize the orb particle [height and width] can anyone tell me how to?
    Alan Lorence replied 18 years, 1 month ago 2 Members · 3 Replies
  • Alan Lorence
    August 20, 2008 at 1:57 am
    Select “height” in the hierarchy then change the value in the graph window by clicking and dragging the data point. Same for “Width”.
    You can also hit “N” to bring up the numeric entry box.
    Alan.
    http://www.wondertouch.com
  • Avery Henderson
    August 21, 2008 at 5:26 pm
    wow, thanks a lot that was a great help!
    i have another question if you could help me, when saving the output, there is a horizontal black line that indicates how much particle illusion will save, do you know how to take that off or make it longer?
  • Alan Lorence
    August 21, 2008 at 8:35 pm
    ————- horizontal line (like the horizon)
    | vertical line
    I assume you mean the black vertical line in the graph. It’s set by the “end frame” edit box in the playback toolbar.
    This page may help with some of these basic questions:
    https://www.wondertouch.com/default.asp?loadContent=quickstart.asp
    Also, if you use the “help” menu when within the application you can find a lot of info in the html docs.
    Alan.
