Activity › Forums › Apple Final Cut Pro › how to reset keyer to default
Posted by Craig Alan on May 9, 2017 at 11:14 pmSomeone was fooling around with both keyer and
luma keyer trying to key with a white background.That didn’t work but now I can’t get the keyer to return to its default.
Imacs (i7); Canon 5D Mark III/70D, Panasonic HPX250P, FCP X 10.3, teach video production in L.A.
Craig Alan replied 9 years, 4 months ago 3 Members · 5 Replies -
Noah Kadner
May 9, 2017 at 11:53 pmYou can always delete any effect with the delete key while selected in the Inspector, which is often easier than going through each parameter and hitting the little reverse arrow reset button at the right side.
Noah
FCPWORKS – FCPX Workflow
FCP Exchange – FCPX Workshops
XinTwo – FCPX Training -
Craig Alan
May 10, 2017 at 4:42 amThanks. I was able to remove the effect from the clip but not the keyer itself I think they may have accidentally set to make the messed up settings the new default while maybe thinking it would return it too the keys default. If that were so would I reset everything and then make that the new default? I even tried unchecking all variables in the inspector but It didn’t change anything.
Noah Kadner
May 10, 2017 at 5:12 amEffects cannot be set to a default.
Noah
Bret Williams
May 12, 2017 at 2:48 amTo reset the keyer settings, simply click the little u-turn arrow at the top right of the keyer effect in the inspector.
_______________________________________________________________________
https://BretFX.com FCP X Plugins & Templates for Editors & Motion Graphics Artists -
Craig Alan
May 14, 2017 at 6:28 pmThanks Noah and Brett. Got a handle on it now.
