Activity Forums Apple Final Cut Pro Legacy How to replace stereo audio clips with multichannel ones of the same timecode in edited film? (FCP 6)
  • How to replace stereo audio clips with multichannel ones of the same timecode in edited film? (FCP 6)
    Posted by Pawel Gardynik on July 19, 2010 at 7:35 am
    Hi everyone,
    I’m about to synchronize video and audio clips in our FCP project yet there’s one question concerning the whole workflow. As the original sound, recorded separately, consists of 5 channels, we’d like to use simple 2-channel versions of it just for the editing and replace them with 5-channel clips afterwards. As far as I know it’s common strategy to avoid too many audio tracks during editing process. Both 2- and 5-channel WAVs have the same timecode of course. In FCP 6, is it posible to sync them automatically in timeline? Or replace them in a way we won’t have to adjust every clip manually?
    I hope my description is sufficient.
    Thanks in advance!
    Pawel
    Nick Meyers replied 16 years, 2 months ago 3 Members · 2 Replies
  • Shane Ross
    July 19, 2010 at 8:56 am
    [Pawel Gardynik] “we’d like to use simple 2-channel versions of it just for the editing and replace them with 5-channel clips afterwards.”
    Don’t. Sync up the second-system audio to your clips now, and edit with all 5 channels.
    [Pawel Gardynik] “As far as I know it’s common strategy to avoid too many audio tracks during editing process.”
    It is? News to me. When I have second system I sync it up, and use every single bit of it in the editing process. It is a necessity. When I want to overlap dialog between characters, or remove overlapping dialog it is pretty vital to have the separate audio tracks. I can’t imagine editing without all the audio.
    [Pawel Gardynik] “Both 2- and 5-channel WAVs have the same timecode of course. “
    EXACTLY the same? Well, then the audio mixer might be able to do an audio conform. But really, it is best for the editor to have all the audio, this way you can perform the needed audio edits. Yes, the picture editor does a lot of audio editing. I don’t know who you were talking to who told you different. I might have 2-4 tracks of video, and between 8 and 24 tracks of audio.
    [Pawel Gardynik] “In FCP 6, is it posible to sync them automatically in timeline? “
    There is no magic replace button. You would have to manually replace each and every clip’s audio. Or export an EDL and then the audio guys would import that and do an audio conform. But talk to them beforehand about the logistics around that. I only did that once, and it made audio editing go longer than it should have.\
    Shane
  • Nick Meyers
    July 20, 2010 at 3:23 pm
    personaly, i’d rather use a mixdown as i edit.
    if i really need more separation, i’ll bring in the multitrack audio for specific clips.
    there IS a way to do what you want,
    it needs to be part of your planning and post workflow from early on, though,
    but i think that’ll work for you.
    its “Matchback Magic” from intelligent assistance:
    https://www.intelligentassistance.com/
    nick
