Activity Forums Adobe After Effects How to render without showing paths?
  • How to render without showing paths?
    Posted by Taylor Fahlman on May 6, 2012 at 7:09 pm
    When I render, for example a title screen in 3D, it shows the little path markers that the text will follow, or a little box in the upper left with a particle generator. How do I make these invisible in the final render?
    Tero Ahlfors replied 14 years, 4 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    May 8, 2012 at 4:13 am
    Motion paths and maskas will not show up in the final export. If it’s a plugin that is in a trial mode it might have some watermarks when you render out.
