Activity Forums Adobe After Effects How to render without audio compression?
  • How to render without audio compression?
    Posted by Jeremy Carr on January 4, 2018 at 3:45 pm
    I made a lyric video in Adobe After Effwcts. I will be finishing in Premiere Pro however I want to render with the audio to ensure the video I created is properly linked to the audio. I’ve tried quick time and Avi and both end up compressing the audio to -18 DB. I’ve spent a lot of time and money on the audio track and want the fully mastered version (0db) after the render. How is this achieved?
    Jeremy Carr replied 8 years, 8 months ago 1 Member · 2 Replies
  • Jeremy Carr
    January 4, 2018 at 3:53 pm
    For further explanation, the audio is 96k 24b and I’m using cs5.
  • Jeremy Carr
    January 6, 2018 at 11:43 pm
    I appreciate your response and your advice. I rendered the lyric animation with the audio to use as a reference. I linked this with the master audio track in PP and it worked well. Soundbooth was useful for increasing the waveform loudness to compare waveforms. I trimmed .033 off the original audio file and it lined up perfectly to my render. Thanks again.
