How To Render With No Quality Loss
Posted by Joao Souza on February 4, 2013 at 8:24 pmLet’s assume I want to render a video with several tracks then import it and apply effects, what format has no quality loss?
Should I use that “render to new track” tool or just render then import it?We have so much time and so little to do! / Willy Wonka
Nick White replied 13 years, 7 months ago 8 Members · 13 Replies -
Andrew Lenczycki
February 4, 2013 at 9:07 pmYou could save your project (with several tracks), then put that saved ‘.veg’ file into another (2nd) .veg project (nesting). Your multi-track original project will show up as a single event on one track. If you right-click on the event, you can open a 2nd instance of Vegas to go back and tweak the editing on the first project in its multi-track incarnation and save it. The 2nd project will automatically refresh the nested original .veg file, then you can apply your affects. When done, render the 2nd .veg project and there will be no quality loss.
Andrew Lenczycki
James Turpin
February 4, 2013 at 9:18 pmDoes this work with Vegas HD Platinum? Or is it just Vegas Pro?
Andrew Lenczycki
February 5, 2013 at 12:05 amAccording to the Sony Creative Software product comparison site at https://www.sonycreativesoftware.com/vegaspro/compare, it doesn’t appear to be an option for you. Sorry. Perhaps one of the more experienced guys have another way to come at it for you.
Andrew Lenczycki
Joao Souza
February 5, 2013 at 12:45 amThanks Andrew but I just want to know which format has no quality loss or at least, less quality loss 😉
Aleksey Tarasov
February 5, 2013 at 4:36 amAny codec which is lossless has no quality loss 🙂
You can try AVI Uncompressed or AVI Sony YUV or MOV PNG (HUGE files!), you can install good lossless codecs such as Lagarith or HuffYUV or… choose yourselfVegasaur | Film grain overlays | Magic Bullet Looks presets | Film Looks for Vegas Pro
Roger Bansemer
February 5, 2013 at 1:09 pmI’ve been under the impression that the Sony MXF file is best. That’s what we use to render our HD programs that go to PBS.
Roger Bansemer – PaintingAndTravel.com
Nick White
February 5, 2013 at 1:16 pmBased on results or experience? Sorry to challenge, but so often rumour will win
Nick
Aleksey Tarasov
February 5, 2013 at 1:19 pmSony MXF is good, but OP wanted a “format with no quality loss”
Nick White
February 5, 2013 at 1:28 pmIsn’t that simply uncompressed? (Huge file sizes: if it was you that said that already then sorry.)
Nick
