Activity › Forums › VEGAS Pro › How to render portion of TL to video on disk
  • How to render portion of TL to video on disk
    Posted by Harry Putnam on August 21, 2010 at 2:27 pm
    I’ve imported an *.mpg format file… and put it on the timeline.
    How can I render a portion of the timeline out to some other format?
    With a section of TL selected, I press File/Render but I’m offered only an audio template… apparently no way to get to a video template to set what format I want rendered section to be.
    On a second attempt, I converted an *.mpg to *.avi container with DV format using Avidemux-2.5
    A Gspot report of the converted file is at the end of this message.
    And finally I imported a captured clip from my sony vx2100 camera which are known to work in vegas and still cannot get a video template to render something.
    (That Gspot report is also included at the end)
    I must have messed up a setting or something. I’ve used vegas on the last mentioned clip once before and had no trouble.
    Some really dumb operator error is at play here I’m sure
    What am I doing wrong… how to export or render out to disk something from the vegas timeline. All I get is a audio choice, nothing is offered in the way of video formats.
    Partial Gspot report on converted file
    — File Information —
    File Name: movie_02(title_3).avi
    File Name (with full path): D:\VIDEO_TS_LydiaExamples\movie_02(title_3).avi
    File Size (in bytes): 783,237,644
    — Container Information —
    Base Type (e.g “AVI”): AVI(.AVI)
    Subtype (e.g “OpenDML”): AVI v1.0,
    Interleave (in ms):
    Preload (in ms):
    Audio alignment(“split across interleaves”):
    Total System Bitrate (kbps): 0
    Bytes Missing (if any): 0
    Number of Audio Streams: 1
    — Video Information —
    Video Codec Type(e.g. “DIV3”): dvsd
    Video Codec Name(e.g. “DivX 3, Low-Motion”): DVC/DV Video
    Video Codec Status(e.g. “Codec Is Installed”): Codec(s) are Installed
    Duration (hh:mm:ss): 1:46.040
    Frame Count: 3178
    Frame Width (pixels): 720
    Frame Height (pixels): 480
    Storage Aspect Ratio(“SAR”)” 1.500
    Pixel Aspect Ratio (“PAR”): 0.889
    Display Aspect Ratio (“DAR”): 1.333
    Fields Per Second: 59.940
    Frames Per Second: 29.970
    Pics Per Second: 29.970
    Video Bitrate (kbps):
    Partial Gspot report on captured clip:
    File Name: bap’0.00.01.11.avi
    File Name (with full path): D:\baptism\sources\capclips\bap’0.00.01.11.avi
    File Size (in bytes): 30,174,572
    Subtype (e.g “OpenDML”): OpenDML (AVI v2.0),
    Interleave (in ms):
    Preload (in ms):
    Duration (hh:mm:ss): 0:08.041
    Frame Count: 241
    Video Bitrate (kbps): 28772
    MPEG-4 (“MPEG-4” or “”):
    B-VOP (“B-VOP” or “”):
    QPel (“QPel” or “”):
    GMC (“GMC” or “”):
    NVOP (“NVOP” or “”):
    H264 (“H264” or “”):
    Quality Factor (bits/pixel)/frame: 2.778″
    Harry Putnam replied 16 years, 1 month ago 2 Members · 2 Replies
  • Mike Kujbida
    August 21, 2010 at 3:36 pm
    Do you mean that you don’t get a render option screen like this?
  • Harry Putnam
    August 21, 2010 at 6:05 pm
    No… I have that same panel… Sorry… I guess what through me was having *.avi in the file type one another install, in which case the templaes menu offers something very different
    If you have *.wav as file type… next time you look all you see are audio formats under the templates dropdown.
    I guess my only excuse is lack of use and getting confused with how the templates change with choice of file type, instead of the other way round. I expected to see a list of all available templates under the template drop down, not just those for audio.
