Activity › Forums › Adobe After Effects › How to render a Video without the background
Posted by Anil Simsik on February 14, 2011 at 3:20 pmI want to make a After Effects template, but the I used trapcode particular and not all have particular. So I want to prerender the particular. I tried it with bg+alpha, but the quality was to bad and the file was to big (800mb). Can someone help me to create a not so big file, without a background and a good quality?
Thank you.
Haris Berbić replied 11 years, 4 months ago 3 Members · 9 Replies -
Jason Mettler
February 14, 2011 at 3:32 pmSorry if this posts twice. Try making any layer you don’t want to include in the render a ‘guide layer’. Right-click on the layer and select ‘Guide Layer’. A small blue number sign will appear by the layer name. This will leave the layer in comp view but will hide it during renders and in any comps the layer is nested in.
Anil Simsik
February 14, 2011 at 6:17 pmI dont want to hide something. I want to prerender my particles, but without a background, no black background, just transparent.
Anil Simsik
February 14, 2011 at 7:24 pmI did this, but the quality of the prerendered particles is very bad and the file is to big.
Jason Mettler
February 14, 2011 at 8:36 pmYou can alter the codec of a quicktime compression to say mp4 instead of ‘animation’. You will trade quality for size no matter what, but I do that occasionally to save size. You also have the option of using Premiere Pro or Final Cut to resample you movie file. I also do this on occasion. Render out of AE in QT and then export out of Premiere in FLV or MPG2.
Are you confident your particular settings are right? -
Anil Simsik
February 15, 2011 at 4:26 pmit works now fine, but the file size dont changed. Do you know how i can make the file about 30mb big?
Anil Simsik
February 15, 2011 at 9:02 pmTwo questions: what is plan b?
And how did Andrew Kramer created his footage, is a .mov file and not that big? -
Anil Simsik
February 15, 2011 at 9:24 pmThank you for your help! I will try Plan b and I think this should be working.
Haris Berbić
April 29, 2015 at 9:43 amHello Dave!
Please can you clarify one thing here: in terms of transparency and file size, it is possible to create separate Alpha channel video in .mp4 and then another in RGB, but I found this not working when imported in Premiere Pro or After Effects and I am missing here something so I ask you what could that be.
