Activity › Forums › Apple Final Cut Pro Legacy › How to remove the top and bottom black band
Posted by Eric Dubé on January 19, 2011 at 1:48 pmHi everyone , i just finished a video and i give it a ratio of 2.35;1 in FCP and was wandering if there a program that let me remove the top and bottom black band .
Eric
Eric Dubé replied 15 years, 7 months ago 3 Members · 4 Replies -
Todd Gillespie
January 19, 2011 at 5:11 pmAre you trying to export a quicktime movie without the top & bottom bar?
Or are you referring to the display with FCP?Todd at UCSB
Television Production -
Eric Dubé
January 20, 2011 at 1:16 amYes, am trying to export a quicktime movie without the top & bottom bar.
Jeff Greenberg
January 20, 2011 at 2:58 pmFCP won’t do it. You added a filter that gives the illusion of a different aspect ratio – FCP is still moving the ‘black bars’ as if it was a graphic.
I’d do this in compressor (vs. QuickTime.) But here’s both.
When you export, you should be able to get to all of the QuickTime codecs along with a button that says size. You’ll have to play around and experiment with the right number for the custom dimensions you want along with the crop necessary.
In compressor, you can specific and adjust this on the Geometry tab.
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com
