Activity Forums Adobe Illustrator How to remove noise flicker from the borders of an object???
  • How to remove noise flicker from the borders of an object???
    Posted by Shay Yellin on October 25, 2010 at 7:25 am
    Hi there everyone,
    I’m very new with illustrator, so this is very basic:
    I’m drawing a normal graphic drawing in illustrator, which i then want to use in Adobe Premiere for a video clip.
    When i insert my finished illustrator image i made (as PNG) into Premiere – i find it’s outline borders with a lot of noise and flickering…:-(
    Attached is a sample JPG from Premiere showing the problem.
    I would be grateful for any insight and tips for solving this problem!
    Shay
    Les Nemeth replied 15 years, 10 months ago 3 Members · 3 Replies
  • Vincent Rosati
    October 25, 2010 at 11:43 am
    I’m guessing this is a transparent PNG. Maybe try saving the image as a PSD, and use that in the Premiere Project.
    Also, regarding the flicker, I’m guessing you mean video flicker on a CRT display. If so, you could right click on the clip in the Premiere timeline and select flicker removal, or otherwise vertically blur the image from 1.5 to 2 pixels. There’s plenty more on this issue in the Premiere forums.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Shay Yellin
    October 25, 2010 at 11:54 am
    thanks a lot Vince!
    that solved the problem…:-)
    Great day for you!
  • Les Nemeth
    October 26, 2010 at 2:52 am
    You can use PNG, just make sure it’s 24bit. The snapshot looked like it was only an 8bit PNG.
