Activity › Forums › Apple Motion › How to remove black border/frame from keyed layer
  • How to remove black border/frame from keyed layer
    Posted by Tom Hancock on August 6, 2008 at 12:58 pm
    I am currently working on a scene which involves layered still images and also some footage of a person shot in front of green screen which I have since keyed out using Motion’s Blue/Green Screen filter – which is placed in the foreground of the 3D ‘space’. The problem I’m having is that there appears to be a sort of ‘dancing’ black edge which outlines the entire frame of the keyed layer. If for example I use the crop tool to say remove the outer left/right areas of the layer, the black outline simply changes shape to match the new cropped shape of the layer.
    Is there a simple way to get rid of this?
    Cheers
    Stephen Smith replied 18 years, 1 month ago 4 Members · 5 Replies
  • Stephen Smith
    August 6, 2008 at 2:35 pm
    Try the mask tool on the keyed clip. Hope this helps.
    Stephen Smith
    Salt Lake Video
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
  • David Bogie
    August 6, 2008 at 3:57 pm
    [Tom Hancock] “he problem I’m having is that there appears to be a sort of ‘dancing’ black edge which outlines the entire frame of the keyed layer. If for example I use the crop tool to say remove the outer left/right areas of the layer, the black outline simply changes shape to match the new cropped shape of the layer. “
    No idea what you mean by that last part.
    Black edges around a keyed source are usually simply alpha interpretation settings for the layer. Change yours.
    did you prerender the greenscreen key? Nest it?
    bogiesan
  • Noah Kadner
    August 7, 2008 at 1:22 am
    Draw a bezier mask around the shot to remove the black areas. It’s called a garbage matte in old-school compositing terms.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
    https://www.callboxlive.com
  • Tom Hancock
    August 7, 2008 at 4:20 pm
    Thanks for the replies. After trying the first two, I was recommended to install the software update (3.0.2) then – magically – problem solved. Weird, but good.
  • Stephen Smith
    August 7, 2008 at 4:53 pm
    How funny, I’m glad that solved the problem.
    Stephen Smith
    Salt Lake Video
