Activity › Forums › Apple Final Cut Pro Legacy › How to reduce sunlight in one corner of video
Posted by Heather Gulledge on April 19, 2011 at 4:29 pmWe are also trying to reduce the glare in the bottom left corner of this video. Is there any way to fix it without affecting the entire screen? Borris brightness/contrast only helps so much.
David Roth weiss replied 15 years, 4 months ago 8 Members · 12 Replies -
David Roth weiss
April 19, 2011 at 4:50 pmSure! you draw a soft-edge elliptical matte that covers that portion of the screen and adjust highlights accordingly. Colorista and Apple Color both have this capability built-in, making this kind of fix duck soup. In FCP, you have to use a combination of filters, matte, soft edge, and 3-way color corrector. This is the kind of thing you should take the time to learn, as it lays the foundation for all kinds of compositing tricks that are very, very good to have up your sleave.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Cody Walters
April 19, 2011 at 4:54 pmYou can take this to color and use the HSL Qualifier, key on luma that specific region and try and reduce the highlights.
If this shot does not have a lot of motion, you could duplicate this clip. On the top clip reduce your highlights. Then mask that portion only with a bit of feather.
That background may be too blown out to salvage, but give it a shot.
Mac Pro 2.26GHz 8 Core
16 GB 1066 MHz DDR3
Final Cut Studio 3
Adobe CS5 Master Suite
Panasonic HVX-200
Canon 7Dhttp://www.codywaltersvideo.com
Heather Gulledge
April 19, 2011 at 5:00 pmThank you both. I will try both options and definitely look for tutorials. I want to learn all I can possibly learn so this goes faster for me.
Tom Matthies
April 19, 2011 at 6:52 pmGoogle: Paul Crisp Garbage mattes.
It will make the masking easy.
TomE=MC2+/-2db
Frank Giardina
April 19, 2011 at 6:56 pmDavid…. thanks for that tip!
Frank Giardina
17 Video Production -
David Roth weiss
April 19, 2011 at 7:16 pm[Frank Giardina] “David…. thanks for that tip!”
Anytime Frank. Especially for you, because you always say thanks. Your mommy obviously taught you well…
David Roth Weiss
Los Angeles
Frank Giardina
April 19, 2011 at 7:21 pmDavid… I’ll tell her you said that, she’ll get a kick out of it. I’m self taught and trying to build a small business for my boys, plus trying to stay one step ahead of the pack. This forum, with experts like you, helps me more than I can express. Everyone is so eager to give back, so to speak. I do what I can to help when I can too.
Thanks Again!!
Frank Giardina
Bret Williams
April 19, 2011 at 10:20 pmYou can do it fairly easily with just the 3 way cc. Use the eye deopper to select that luma range or do it manually. Adjust the luma range area until the matte has a nice soft edge. Then lower the brightness, etc.
But a better idea might just be to duplicate the layer above itself. Then matte out (with 8 ppoint garbage matte – I hear FCP X will boast 10 points!) a good chunk of leaves from above and then move them down onto the bright area. Make sure to soften the matte. Will only work well if the camera is locked down.
Michael Gissing
April 19, 2011 at 10:50 pmWith both the HSL key in Color or Limit Range HSL keying in the 3WayCC, you can not only reduce the blown out highlight, but you can color it blue so it looks like sky poking through. You will need to soften the key.
