Activity › Forums › Adobe After Effects › how to reduce .mov file size?
  • how to reduce .mov file size?
    Posted by Koko Phasinsaksith on December 22, 2009 at 10:24 am
    hello,
    i’ve rendered out from AE and it quites a big file 1,11 Gb .mov file, how can i reduce this file size because it so big..Help!!
    (render with animation setting)
    thanks in advance..!!
    Koko Phasinsaksith replied 16 years, 9 months ago 2 Members · 2 Replies
  • Todd Kopriva
    December 22, 2009 at 5:00 pm
    You produce a smaller output movie by choosing an encoder that does more compression. You do this in the output module settings. For QuickTime containers, there are many good encoders that compress efficiently. You choose your encoder for QuickTime movies by clicking the Format Options button in the Output Module Settings dialog box and then choosing from the Compression Type menu.
    Exactly which one you pick depends on exactly what you’re going to do with the movie. If you’re handing the movie off for someone else to work with—say, you’re handing off a visual effects shot for someone else to incorporate into a longer movie—then you want to use lossless compression. If, on the other hand, you’re creating a movie for people to watch on the Internet, you want to use much heavier compression (at the loss of some quality).
    See “Encoding and compression options for movies”.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Koko Phasinsaksith
    December 28, 2009 at 12:51 pm
    thank you very much..^^
