Activity › Forums › Apple Final Cut Pro Legacy › how to reduce echo from an audio file?
Brian Dalton replied 14 years, 10 months ago 6 Members · 12 Replies
Stephen Etchie
December 9, 2009 at 8:45 pmWhen you right click the timeline and send the audio to SP (as you said you did in this thread) a file is created (it should have asked you where to store the file). When you finish doing whatever you were doing in SP, if you save it, the audio file in the timeline of FCP will automatically become what you saved.
Brian Dalton
November 16, 2011 at 7:17 pmThanks Jeff, This worked better than I expected. My audio was recorded using a zoom H4n and a wired Shure Lavaliere. When i sat down to start cutting, I noticed a similar hiss and “hollow” quality to the audio. I chalked it up to recording in a glass encased conference room. Your advice helped tremendously, thanks again.
