Activity › Forums › Adobe After Effects › How to recreate Layerlab feBiomass.
Posted by Marshall_teller on July 3, 2005 at 6:05 pmHi any one know how to recreate the feBiomass, tiBiomass or geBiomass project?
info: https://www.layerlab.com/vproject.aspx?pID=95&catID=1&Category=Projects&levelID=1&i=1&f=Y
Thanx a bunch.
Mylenium replied 21 years, 2 months ago 3 Members · 3 Replies -
Filip Vandueren
July 3, 2005 at 10:11 pmfor feBiomass:
- Create a solid layer
- give it a Fractal noise effect
Settings:
Fractal Type: Dynamic
Noise Type: Spline
Contrast: 160 - Precompose that layer, moving all attributes into the new comp, name it “Blob”
- on the Blob Layer: add a colorama effect
Twirl open the Output cycle and choose use Preset palette: “Ramp red”
Double-click on the red triangle and change the red color to rgb (255/128/125) pink
click on the opposite side of the (now pink) triangle to add another triangle and choose rgb (128/0/0) dark red - add a CC Glass effect
Settings:
Surface->softness: 1,0
Surface->height: 20,0
Surface->Displacement: 0,0
Shading->Ambient: 100
Shading->Specular: 66
Shading->Diffuse: 0
Shading->Metal: 0
parameters that are not mentioned can be left to their default values.
Here’s my result:
If you now animate the evolution-option of the noise in your pre-comp you get some pretty yucky stuff 😉The Green one is just another noise-preset, with a different colorama, even without any other effects applied after that I believe.
Filip Vandueren
July 3, 2005 at 10:23 pmWell, I only watched the stills, now I watched the animated version, and indeed , you can just animate the evolution to get what they did.
You also might want to fine-tune the brightness & contrast settings of the fractal noise to get another balance, fe. contrast 200%, brightness -50 also give snice results etc.
All this being said, it looks to me like everything Layerlab are selling is just based on different fractal noise settings, I hope I didn’t put them out of business by recreating one effect here in about 5 minutes time 😉
Mylenium
July 4, 2005 at 6:29 pm[Filip Vandueren] “All this being said, it looks to me like everything Layerlab are selling is just based on different fractal noise settings, I hope I didn’t put them out of business by recreating one effect here in about 5 minutes time ;-)”
Well, I think few people would miss them… Most of their stuff is so ridiculously simple, it’s really quite impertinent of them to even ask for money for it.
Mylenium
[Pour Myl
