Activity › Forums › Apple Final Cut Pro Legacy › How to record audio directly into FCP 6?
  • How to record audio directly into FCP 6?
    Posted by Beau Brotherton on April 28, 2008 at 8:38 pm
    Hello to all,
    This might be a dumb question, but is there a way to record audio directly into FCP 6?
    I have an AJA LHe and Mackie 1202-VLz3
    We have a project that has 20 something individual spots that need VO scratch tracks so that the client can have an example of what the spot will be with the script.
    I have been using my HVX200 to record to P2, then log and transfer, then remove video and copy and paste the audio where needed.
    I know someone out there is laughing, but I don’t know how else to do this. I’ve never used pro tools, sure that would be the first clue. But do you have to have specific application or can Soundtrack do this?
    All I need to do is go from a phantom power mic to, something of this computer.
    Thanks for your help and have a good one.
    Best,
    Beau Brotherton
    Macbook Pro 2.4GHz, Intel Core 2Duo, 4GB
    FCP6
    HVX200
    Howard Harper replied 17 years, 10 months ago 4 Members · 5 Replies
  • Walter Biscardi
    April 28, 2008 at 8:43 pm
    Run your mic to the Mackie
    Turn on the Phantom Power
    Launch FCP
    Launch the Voice Over Tool
    Capture.
    If you’re not exactly sure how the VO tool works, just launch Help and type Voice Over Tool.
    Alternatively, you can launch Quicktime Pro and record your audio tracks there and then bring those into FCP. This is actually what I do. You just ensure that the AJA Kona is your Audio Input device in System Preferences.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Jeremy Garchow
    April 28, 2008 at 10:42 pm
    Soundtrack Pro works pretty decently for this as well.
  • Jeremy Garchow
    June 3, 2008 at 8:51 pm
    [Cedric Nairn- Smith] “I have a hand held mic plugged into my companion 5 speakers. I am still unable to record sound.”
    You have to plug your mic in to a mixer, your mixer then needs to go to a capture card of some sort, then open up FCP/STP and record sound.
    Your speakers are not an input device, they are an output device.
    Make sense?
    Jeremy
  • Jeremy Garchow
    June 4, 2008 at 5:28 pm
    That will work.
    The Blu Snowball work very well for this too if you need something a little more high end.
    https://www.bluemic.com/modules.php?op=modload&name=Products&file=index&prod_id=18
    Jeremy
  • Howard Harper
    December 5, 2008 at 4:56 pm
    MXL Make a mic called the Studio 1. It is USB, plus has a headphone socket for zero latency monitoring. This works great for getting narrations etc into FCP. Plus it’s under a hundred bucks.
    https://www.mxl-usb.com/Studio1USB/Studio1USB.htm
