Activity › Forums › DaVinci Resolve › How to reconform an XML when Red footage is on more than one drive
Posted by Robert Ruffo on January 21, 2013 at 12:25 pmReconforming an XMl based on pointers to .mov files to R3D usually works well, but…
DaVinci asks me to look in only one place – but the footage is spread over two raids. Is there any way to make this work? I’m dealing with 100s of files, and no single drive is large enough to handle them all.
Jake Blackstone replied 13 years, 8 months ago 4 Members · 8 Replies -
Jake Blackstone
January 22, 2013 at 5:41 amYou are using V9 right? Unless I’m misunderstanding, are you saying, that when you use XML and Resolve doesn’t find all files it doesn’t ask you, if you’d like to look in other places? Because it should.
Simon Blackledge
January 22, 2013 at 10:19 amIt does ask I think he says.
Issue is he can only select one destination.
Can’t you command click multiple dest ?
otherwise just lob all the media into media pool before loading the XML
s
Jake Blackstone
January 22, 2013 at 7:42 pmI haven’t noticed, that you can only access only one drive, when resolve asks you for the additional locations. In that case, why not create an alias of the folder needed from another drive? Resolve understands aliases…
Kevin Cannon
January 22, 2013 at 9:21 pmHi Robert,
I think the command you are looking for is “import additional clips with loose/tight filename match.”
Once you import an XML and point it to the first drive/directory (and half the clips are missing), then right click on the timeline name and select “import>additional clips with loose filename” match to select another drive/directory. It will use the original XML and look in that folder, adding more media to the media pool.
Cheers,
KC
Jake Blackstone
January 23, 2013 at 2:24 amJust checked the possibility of using additional folders on other drives with aliases and, unfortunately, Resolve doesn’t see them.
Jake Blackstone
January 23, 2013 at 2:33 amIt seems I’m missing something. I just tested importing XML and Resolve allows you to import as many times as you like from as many drives as you like too….
Robert Ruffo
January 25, 2013 at 3:23 amHey Jake!
You mean you import the same XMl twice, and each time it adds more stuff to the media pool?
ANd Cannon, thanks for the GREAT tip, I’ll try it!
Jake Blackstone
January 26, 2013 at 2:58 amNo, that’s not what I meant. Import XML and Resolve will ask you where to look. If resolve finds all needed files in the first folder, you’re done. Otherwise, Resolve will ask you again, if you want to stop or if you’d like to continue to look in another folder, which can be on another drive. Select yes and select another drive and folder there and Resolve will continue doing that, until everything had been found.
