Activity Forums Adobe After Effects Expressions how to read a value using an expression ?
  • how to read a value using an expression ?
    Posted by Sebastien Allain on July 5, 2007 at 10:35 am
    Let me explain,
    if you have something like the opacity driven by an expression:
    transform.opacity=value*100
    The result is the value of the opacity multiplied by 100, right.
    Now I would like in an other expression (transform.position) to read the original value of the opacity! if I link position to opacity, the result is the whole expression of opacity …
    Is there a way to directly read the original value of the opacity ?
    sebastien
    Sebastien Allain replied 19 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 5, 2007 at 7:53 pm
    If the pre-expression value isn’t animated, you can use a little trick where you use the opacity expression to stuff the pre-expression value into negative times, like this:
    if (time >= 0) value*100 else value
    Then you pick up that value like this:
    transform.opacity.valueAtTime(-1)
    If the pre-expression value is animated, you can still do it with something like this:
    if (time >= 0) value*100 else valueAtTime(-time)
    and pick up the value like this:
    transform.opacity.valueAtTime(-time)
    But you have to do a little extra work to pick up the pre-expression value at time = 0, if you need it. Anyway, that should give you the idea.
    Dan
  • Sebastien Allain
    July 5, 2007 at 8:00 pm
    the time reversed ! i love the idea…
    always, so effective way Dan !
    thanks
    sebastien
