Activity › Forums › Adobe After Effects › How to re-link illustrator layers;
Posted by Frank Weber on June 15, 2010 at 10:41 amHi,
How do you e-link Illustrator/Photoshop layers, once they’ve gone missing/changed file-names, all at once, not one by one?Thanks.
Steve Roberts replied 16 years, 2 months ago 2 Members · 7 Replies -
Steve Roberts
June 15, 2010 at 1:42 pmIn CS4, double-clicking on an Illy layer in the project window links everything else, if the relationship between files and layers hasn’t changed. Unless I’m mistaken …
Frank Weber
June 15, 2010 at 1:55 pmThanks. But: If the file name has changed, all the layers are “lost” in AE.
Re-linking one layer, doesn’t automatically link the rest.
I’m getting Carpel-Tunnel from re-linking layers. -
Steve Roberts
June 15, 2010 at 3:52 pmWhy don’t you rename the file to the old filename?
(You know not to do that again, eh?) 🙂
Frank Weber
June 16, 2010 at 10:51 amLayers often get misinterpreted by AE, regardless of the file name.
If you ad or delete layers in an Illustrator file, the existing layers distort in AE.
When you re-import, you have to import each layer, in the said file, one by one.Do you know what I’m talking about?
Steve Roberts
June 17, 2010 at 2:56 pm[Frank Weber] “If you add or delete layers in an Illustrator file, the existing layers distort in AE. “
Oh, yes. That’s always a bad idea.
