Activity › Forums › Avid Media Composer › How to re create deleted mxf files from the original footage?
Chip Hess replied 9 years, 3 months ago 6 Members · 12 Replies
Michael Phillips
May 19, 2017 at 3:14 pmAlso be aware that re-importing ala batch reimport assumes that the clip has not changed in duration, so make sure it is the original master clip that as first created. If not, Media Composer will force fit the source to the clip making it remove or add frames which is not a good look.
Michael
Chip Hess
May 20, 2017 at 11:13 pmThis is tremendously helpful, I knew there was a way!
Thanks very much for the info, all.
