Activity Forums Avid Media Composer How to re create deleted mxf files from the original footage?
  • How to re create deleted mxf files from the original footage?
    Posted by Togan Gokbakar on April 28, 2014 at 2:45 pm
    I have a very large project consisting of 100 hours of 2K prores444 footage. So ,we created mxf proxies for the edit. After we finalise the edit for project I deleted the mxf files from the disk to create some free hdd space. Now after 3 months I need to re edit some stuff. How can I re transcode and get the same mxf from the original footage in a short automated way? My project and everything is intact. Just my mxf files are offline.(Avid version is Avid Media Composer 7 mac)
    Chip Hess replied 9 years, 2 months ago 6 Members · 12 Replies
  • 12 Replies
  • Richard Sanchez
    April 28, 2014 at 4:00 pm
    Were your dailies originally created using Resolve or another dailies processing software? Those programs will typically add a tape name to your media for tracking purposes, and depending on how you set the program, the naming convention for those dailies could vary so it will be important to make sure those match.
    If this is not the case and your dailies were originally imported or AMAed and transcoded, the simplest solution would probably be to batch import.
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Togan Gokbakar
    April 28, 2014 at 4:02 pm
    My dailies are my original camera files directly out from alexa. Out from Alexa 2k Prores 444 , transcoded as imported to avid to a lower quality proxy. Editied from the proxy. I deleted the proxy mxf’s. How can I re create them from the original files.
  • Michael Phillips
    April 28, 2014 at 5:27 pm
    Richard is asking how the MXF files got created in the first place – via a third party dailies system like Resolve, or via a transcode via AMA linking directly to the camera originals? The answer you provide, changes the answer we provide.
    Michael
  • Togan Gokbakar
    April 28, 2014 at 6:15 pm
    Sorry for misunderstanding.Mxf files created via AMA linking directly to the camera originals than transcoding them in the bin. Thanks
  • Michael Phillips
    April 29, 2014 at 4:28 am
    Can you not AMA access the camera originals for the files that missing?
    Michael
  • Pat Horridge
    April 29, 2014 at 11:48 am
    If you originally AMA linked the files and then transcoded to make MXF media (this isn’t importing as that’s an older legacy way of ingesting media). Then you create a new empty bin in your project and the AMA link all the required sources you need. (using the set bin display you can select show reference clips to get a list of clips needed and if you turn on the column headings source name and source path it will even show you what and where to find them)
    Once AMA linked you can select all and re-transcode to whatever quality you need and then relink the sequence to that media (or link the sequence to the AMA sources if you prefer)
    https://vet.co.uk/training/courses/vet-production-and-editing/avid-media-management-for-media-composer/
    All covered in the neat 2 day course I run fro VET 🙂
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Chip Hess
    May 18, 2017 at 12:46 am
    Pat,
    Found this old post which answers a question I just asked.
    Does this work with imported media, as well? I have found
    AMA to not work in one project, synching tracks with video
    would drift over time in long takes.
    In that instance, could I re-import the original cam files
    and link the mxf created into the sequence?
  • Michael Phillips
    May 18, 2017 at 12:49 pm
    Are you referring to batch reimport?
    Michael
  • Chip Hess
    May 18, 2017 at 2:16 pm
    Is that what would work? I have never had to cross this bridge, so I am all ears.
  • Glenn Sakatch
    May 19, 2017 at 2:21 pm
    If at some point you actually imported clips, and cut with them, then yes you can simply batch Re-import.
    Either select you sequence and right click, batch re-import, or select the clips in the bin and select batch re-import.
    Avid will ask you if you want to do all clips or just offline media.
    it will then ask you to confirm file locations for the media you are bringing in.
    If the file location has changed, you will need to select all the files, and point avid to the first file, and it should figure out the relative location of the rest of the files.
    (I wish AMA did this!!!)
    Obviously you need access to the original media.
    This is also handy for graphics that change during the course of an edit.
    right click the original graphic file, when it asks for the location, point it to the new version, and re-import.
    Note re-importing doesn’t delete the old media.
    If you are re-importing clips that are online, you will double up your media files, so usually best to delete any media files first if you are doing a swap out of graphics.
    Glenn
