Activity › Forums › Adobe After Effects › how to rasterize a ai file in ae?
  • how to rasterize a ai file in ae?
    Posted by Jeremy Webb on May 11, 2005 at 6:08 pm
    is there a way to rasterize an .ai file in ae 6.5? i have scaled it up quite a bit, and am exporting to swf and the flash guy wants no vectors. i was hoping for a simailair method to photoshp’s right clicking on a layer and selecting rasterize.
    Steve Roberts replied 21 years, 4 months ago 3 Members · 2 Replies
  • Aric Whittom
    May 11, 2005 at 6:18 pm
    In the switches column next to the layer you should have a column that has an * (asterix). If you can add a check box to that layer in that colum that means it can be “continiously rasterized” It should be next to your draft quality “/” switch.
  • Steve Roberts
    May 11, 2005 at 6:42 pm
    Odd that he wants no vectors.
    I’d render as a JPEG sequence using the render queue, then let the flash guy import that sequence.
    Steve
