Activity Forums Apple Final Cut Pro Legacy how to put time lapse stills into a movie?
  • how to put time lapse stills into a movie?
    Posted by Brad Kopp on August 22, 2009 at 1:44 am
    I have a sequence of still pics shot once every two seconds. is there a way to simply put them into a film strip for a time lapse movie?
    Margus Voll replied 17 years ago 3 Members · 2 Replies
  • Rafael Amador
    August 22, 2009 at 2:39 am
    Hi Brad,
    In your User Preferences set Stills Duration; 1 frame.
    Import the folder with the stills, select and drag to the time-line.
    Cheers,
    Rafael
    http://www.nagavideo.com
  • Margus Voll
    August 22, 2009 at 6:31 am
    Hi.
    If you only need every frame to be 1 frame long then you could import those also to QT Pro and save as mov.
    I say this as it is much easyer to operate with it on fcp timeline.
    In fcp you could use 2, 3 or 5 etc frames per one still frame which gives you more room in artistic way. Still i’d export this frames folder from timeline and would import it again to fcp timeline for easyer operation. Maybe it is more question of work habit 🙂
    See what way works for you better.
    Margus
    https://iconstudios.eu
