Activity › Forums › Adobe Premiere Pro › How to properly interlace 29.97 progressive film
  • How to properly interlace 29.97 progressive film
    Posted by Jonathan Redford on July 1, 2014 at 2:44 am
    Hi All,
    I have a film master that is edited and exported in 29.97p.
    I need to convert the master to 29.97 interlaced for iTunes delivery.
    I have tried all the things suggested here on CC with no luck.
    – Compressor exporting as interlaced with both ‘reverse telecine’ and ‘best’ retime settings.
    – PrPro interpreting the footage as interlaced
    Is there a proper way to interlace a progressive file?
    If not, I am open to converting the 29.97p to 23.98p.
    Luke Pearson replied 12 years, 3 months ago 3 Members · 4 Replies
  • Luke Pearson
    July 1, 2014 at 5:52 am
    Hi Jon,
    iTunes will accept 29.97 progressive content.
  • Jonathan Redford
    July 1, 2014 at 6:11 am
    Unfortunately, they do not here in Australia.
  • Tero Ahlfors
    July 1, 2014 at 6:37 am
    The spec sheet says:
    “29.97 interlaced frames per second video source can be delivered either interlaced or de-interlaced properly tagged as progressive”
    But if you want to “interlace” it then just render it out as interlaced, upper fields first.
  • Luke Pearson
    July 1, 2014 at 8:31 am
    The iTunes spec is the same globally.
