Activity › Forums › Panasonic Cameras › How to properly capture 480i/30p squeeze to FCP?
  • How to properly capture 480i/30p squeeze to FCP?
    Posted by John Garcia on June 17, 2009 at 11:15 pm
    Hello everyone,
    I recently shot a dance recital on the HVX – mini DV- at 480i / 30p – aspect ratio = squeeze.
    I want to know how to correctly capture on FCP because I must of done it wrong the first time around. Because the footage looks crappy compared to when I view it on my TV via the HVX and composite cables. Even on the LCD on the HVX it looks fine when in VCR mode. I really think I captured wrong because the reds BLEED right off the edges too!
    I would appreciate any input guys! thanks in advance!
    Diego
    John Fishback replied 17 years, 3 months ago 4 Members · 3 Replies
  • Steve Eisen
    June 18, 2009 at 12:08 am
    Anamorphic!
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Diego Garcia
    June 18, 2009 at 1:01 am
    Steve thanks for your time/reply. I’m so confused. I dont understand why on my timeline in FCP my footage looks like: what looks like 16:9
    https://uploadpic.org/showpic-2750/picture_1.png
    and then when i export quick time (current settings) i get this: what looks like 4:3
    https://uploadpic.org/showpic-2753/picture_2.png
    i dont understand it. all i want is to export as 16:9 and have it look great just as it was shot.
    Thanks again
    D
  • John Fishback
    June 18, 2009 at 3:24 pm
    The file you exported from FCP is squeezed. If you encode it with Compressor and make a DVD with DVDSP and tell DVDSP that the file is 16:9, your DVD will play 16:9.
    If the QT file is the final product and needs to play 16:9 you can open the file with QT Player (PRO) and export it changing the Aspect Ratio choice in Options to 16:9. You can also do this out of FCP by using Export > Using QT Conversion by opening Options and in the Video Settings select Aspect of 16:9.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
