Activity Forums Adobe Illustrator How to programmatically create this vector shape?
  • How to programmatically create this vector shape?
    Posted by Bob Honda on July 2, 2010 at 9:07 pm
    I have a cardboard cut-out of something I want to create.
    https://38.99.165.179/kalle/vector.png
    I’ve taken a picture and made a vector outline that I’m satisfied with.
    https://38.99.165.179/kalle/vector2.png
    Now to get those holes, there’s a variety of ways to do it… but I want accuracy, so does anyone have a suggestion how to pull it off?
    Methods to achieve the evenly spaced holes inside the piece?
    1 – SLOPPY – Draw each segment by hand, using photo as a background reference.
    2 – SLOPPY – Draw a rounded corner rectangle then duplicate/scale/edit it for each segment.
    3 – SLOPPY – Bring prepared photo in and use Illustrator’s LiveTrace feature to convert the shapes into vector. I tried, with variations. Have to tweak each individual segment after.
    4 – PREFERRED – Somehow tell the computer to generate X number of objects along Y path, making them smaller and smaller.
    Using Illustrator, Method 4 can ALMOST be done in a number of ways…
    4a-Make a rounded corner rectangle, duplicate it off in a straight row, group them together, then use something like Warp.
    4b-Make a rounded corner rectangle, duplicate it off in a straight row, group the together, then use 3d extrude & rotate and extract the results.
    4c-Make a rounded corner rectangle, use Transform and replicate it X times and adjust horizontal/vertical positioning and scale.
    I like 4c but still not close. How can I restrict it to be along a pre-determined path (an arc)? Like text-on-path tool, but with shapes, and scaling down progressively like a warp.
    Anyone have any advice?
    I need/want precision because this is a part that will be cut out of a CNC machine for something that’ll be at a tradeshow.
    Vincent Rosati replied 16 years, 2 months ago 2 Members · 1 Reply
  • Vincent Rosati
    July 2, 2010 at 9:54 pm
    Maybe not the answer you’re looking for, but to “tell the computer to generate X number of objects along Y path, making them smaller and smaller”
    Create just the small and big objects and…
    Object/Blend with Specified Steps, then Object/Blend/Replace Spine.
    Use a 2-point path as the spine, with Bezier curves on both points.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
