Activity Forums Adobe After Effects How to produce a glass rods overlay effect?
  • How to produce a glass rods overlay effect?
    Posted by Sasha Smolin on April 16, 2017 at 11:02 am
    Hello, I am currently trying to produce a piece of visual artwork for a large led screen which will be a featurepiece in a lobby. The screen size will be 9m x 3m!
    The brief is simple: To film a 24hr segment from the top of our building (sunrise to sunset) and then overlay the effect of glass rods/curved glass on top of the segment.
    Currently I have experimented with the AE ‘Wave Warp’ modifier with some success.
    The effect of glass rods however, I am finding hard to achieve. For this I have made a black and white gradient image in Photoshop, which I have then overlaid over the segment in addition to the Wave Warp modifier.
    I have also tried to put a glassy texture (together with normal map) in front of the segment as per Andrew Kramer’s glass tutorial [youtube]https://www.youtube.com/watch?v=WZW8kDQWQ5I%5B/youtube%5D – but the effect is still not there for me.
    Please see my current tests below. If anyone could help me improve the glass rods effect I would be very grateful!
    A still from the unedited 24hr video segment:
    Glass rods inspiration images:
    Or curved glass:
    Another curved glass image:
    My gradient map:
    My current output:
    Again, any help on achieving the glass rods effect much appreciated. Thanks!
    Sasha Smolin replied 9 years, 4 months ago 4 Members · 5 Replies
  • Richard Garabedain
    April 17, 2017 at 3:06 pm
    use your gradient map as a displacement map instead of a overlay…also you might have to work on your gradients a bit so that they look more like glass..maybe use a bulge..make one first.
  • Sasha Smolin
    April 17, 2017 at 3:55 pm
    Thanks for the replies. I have played with it a bit more and have got a better result. The next step is to introduce bulges to the gradient map as you have cleverly suggested!
    Regarding the 24hr playback – this has not been thoroughly thought through. I have assumed using the right codec/compression-mode will allow for this. I presume you think that the file will be so large that it will not be playable?
    The screen will comprise of 60 or so frameless LED screens clamped together. A separate company that specialises in this will do that. All the screens will then be hooked up to a central computer where we can display any video.
    Here are my current tests. I added clouds to help with seeing some distortion through the rods.
    In this image the rods (ie the gradient map) is not displaced, but an ice normal map texture is – as per Andrew Kramer’s glass tutorial.
    In this image the gradient map is displaced. Not a big difference, but still a nice effect.
    Please let me know your thoughts.
  • Cassius Marques
    April 17, 2017 at 4:50 pm
    All I’m seeing on your effect is the refraction that overlaying glass would create. But with glass its reflection is more prominent than its refraction.
    I think (not at all knowing the look you’re after) that adding some highlights and lowering that noise distortion would sell the effect better.
    Cassius Marques
    http://www.zapfilmes.com
  • Walter Soyka
    April 17, 2017 at 6:40 pm
    The CC Glass effect will let you do both distortion and lighting. You can re-use the elements you’ve got already.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Sasha Smolin
    April 17, 2017 at 8:07 pm
    Thanks for all your comments. Very helpful.
    Regarding the CC Glass effect, I didn’t find it that useful, but this then led me to the caustics effect which I think is very cool. It works by having input for three layers – one for the seafloor, one for the waters surface and one for the reflection of the sky.
    For the seafloor layer I input the image of my skyline
    For the waters surface I input the rods greyscale image
    For the sky reflection I left blank as I have not found a suitable image for this yet (but this is potentially very useful)
    As this project is essentially a piece of artwork, I am quite happy with the exaggerated distortion . There are also so many settings to play with in the caustics effect that this could be easily reduced if desired.
    Regarding the length of the video – I can now image that we will have to reduce the segment to capture everything from sunrise to sunset and a little bit after. This will therefore take the total segment length to something like 16 hours. Then we will have to compile a number of three hour AE segments in premier once they are done.
    If anyone has more suggestions please let me know and thanks again.
