Activity › Forums › Apple Final Cut Pro Legacy › how to print timeline on paper in final cut
Posted by Luk Warzecha on October 14, 2009 at 9:51 pmhi!
Is any body knows how can I print final cut timeline? I mean all you see on monitor. I dont wont print to video from timeline (export). I want to print on paper what I see on timeline (like screen printing), but whole movie (10 min). I need it for my work (I need do notes about each frame).
Sorry for my english!
bagus
Mark Suszko replied 16 years, 10 months ago 5 Members · 5 Replies -
John Fishback
October 14, 2009 at 10:06 pmCheckout Digital Heaven’s Final Print
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Luk Warzecha
October 14, 2009 at 10:43 pmthanks!
Its goog, but it`s not what I expect. I need all timeline view (video with filmstrips and audio chanels with waveforms). Do you have some idea?bagus
Kai Cheong
October 17, 2009 at 10:52 amI’ve not heard of any software or plugin that does it, so perhaps you might want to consider going the longer route of using ‘Print Screen’ and then printing out the screen shots?
You can go to Sequence Settings > Timeline Options and choose ‘Thumbnail Display > Filmstrip’ and also ‘Show Audio Waveforms’. Then on the timeline itself, expand it as big as possible. Just keep adjusting your timeline across the screen and doing ‘Print Screen’. If you want to tidy things up, you could crop out what you don’t need in Photoshop.
It might not be ideal and it’ll be easier if you’re working with a bigger monitor, but it could give you what you need.
Kai
FCP Editor / Producer with Intuitive Films
https://kai-fcp-editor.blogspot.com
Now ‘LIVE’! Check Out The Intuitive Films Blog @ https://intuitive-films.blogspot.com
At Intuitive Films, We Create: TV Commercials, Documentaries, Corporate Videos and Feature Films
Visit us @ https://www.intuitivefilms.com
MacBook Pro 2.4GHz | 4GB RAM | FCP 5.1.4 | Mac OS X 10.5.2 -
Joel Wenz
October 20, 2009 at 4:39 amI’m with Kai on this, open FCP and click your timeline then hold shift + z (this should fit your timeline to the screen, then screen cap the timeline (hold down shift, command and 4 all at the same time and don’t let go) your cursor will turn into a cross hair, just drag a box around the timeline and boom done, no photoshop needed 🙂
-j
Mark Suszko
October 29, 2009 at 2:07 pmI just use Apple’s built in Grab tool, leave an icon shortcut to it in the dock.
