Activity Forums Adobe After Effects How to preview when rendering?
  • How to preview when rendering?
    Posted by Aditya Wildan on March 19, 2019 at 9:43 am
    Hi, how do i preview when rendering anything in after effects?
    previously i use After Effects 2012 and preview panel show the progress when rendering anything. but, since i use After Effects 2015.0 release (version 13.5.0.347) this no longer works, do i miss something in preferences? what should i do?
    thank you
    Michael Szalapski replied 7 years, 6 months ago 3 Members · 2 Replies
  • Mike Sevigny
    March 19, 2019 at 7:05 pm
    I believe this was replaced with the use of “Add to Adobe Media Encoder Queue”.
    If you send your renders to AME, you can continue to use AE and keep adding to the queue as you work.
    Mike
  • Michael Szalapski
    March 19, 2019 at 10:39 pm
    Also, you should seriously consider updating. You are using the buggiest version of After Effects I can recall using. If you can’t upgrade to the latest versions 15 or 16 (commonly called CC 2018 and CC 2019), I’d recommend at least updating to version 13.7.x (I can’t remember what the latest number was – at least 13.7.1). They fixed a huge amount of bugs that were introduced in 13.5.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
