how to prepare an image for HD Video and use in after effects
Hello
I want to know the correct settings and pixel aspect ratio to use in preparing an image for HD video. I want to then work on this image in After Effects and eventually export it as a HD video. I am confused what aspect ratio I should use for HD video. The problem is I already started to work on the image and used the HD DVC PRO 1080 (1.5) setting as I followed advice from a link online for 1080 x 1920 HD. In Photo Shop when viewing the image I have the pixel aspect ratio clicked on so the image looks like the correct aspect ratio, however when I import this to AE the image does not look right. It looks squashed. As I have already invested some time in creating the image in Photo Shop I want to know if I should have chosen different settings for my image ( HDTV 1080p – square pixels) in the first place and if I now have to start all over again!!! Or can I change the settings of the image I have been working on?
Thank you! I would really appreciate any advice
