Activity Forums Apple Final Cut Pro Legacy How to play 4 frames pr. second
  • How to play 4 frames pr. second
    Posted by Per Ottesen on September 30, 2007 at 3:28 pm
    I have a case, where the security camera records 4 FPS in a file, where the file “identity” says it’s a 30 FPS file.
    When playing in normal framerate it certainly goes fast, and I’ve found a work-around by exporting the movie to an image sequence, and then import this sequence, and let it”s frame be around 4-5 frames (it isn’t “allowed” to maken ANY interpolation, so the images shall be 100% as the original).
    The lowest framerate I can set in FCP is 23.98, so is there another (more smooth) way to solve the problem, so I perhaps can play 4 FPS in FCP, since there are more than 100 files, and the format isn’t quicktime, so it has to be converted on a PC ?
    Per Ottesen replied 18 years, 12 months ago 4 Members · 6 Replies
  • Chris Poisson
    September 30, 2007 at 3:41 pm
    Per,
    Compressor has some incredible features in the latest version, gotta believe it can do this for you, with some tweaking of course.
    Have a wonderful day.
  • Per Ottesen
    September 30, 2007 at 4:33 pm
    The problem is, that the original files is in Microsoft MPEG-4, so I’ve use Sorenson Squeeze on a PC, to transcode it in to H264 with the original settings: 30 FPS, 640×480, square pixels, and then I use Compressor to transcode it into an image sequence, so it’s both a playback issue, and a format problem
  • Michael Sacci
    September 30, 2007 at 6:06 pm
    This is a solution to play 4fps in FCP and for it to not look sped up.
    You would have to use a duplicate frame scenario, the best timeline would be 23.98P and each frame would be duplicated 6 times. On playback it would be unaltered. I would have no idea how to automate this process.
  • Rafael Amador
    October 1, 2007 at 7:38 am
    It may be useful for you the “Joe’s Frame Rate Adjuster”, From the Joe’s Filters. May work.
    rafael
  • Rafael Amador
    October 1, 2007 at 7:44 am
    Joe have another plugin. In the READ ME says:
    “Joe’s De-Multiplexer
    Unless you’re into video forensics and surveillance, this probably won’t be of any use. If you are working with Multiplexed security video, please drop me a note, I really want your feedback on this one. joe@joemaller.com“.
    Rafael
  • Per Ottesen
    October 1, 2007 at 12:41 pm
    Great, I’ll give it a try, thank’s for the suggestions
