Activity › Forums › Adobe After Effects › How to place black sensor bars over a shirt?
  • How to place black sensor bars over a shirt?
    Posted by Edward Calabig on January 21, 2008 at 10:14 am
    I need to place black sensor bars over a shirt in scene with multiple cuts. What’s the best way to do this?
    I’ve tried making a subtraction mask in the shape of rectangle, but I can’t get AE to motion track it properly… what am I doing wrong?
    Also, is there a way to keyframe it by hand? The rectangle constantly changes shape and I think this might be easier. thanks.
    Steve Roberts replied 18 years, 8 months ago 2 Members · 3 Replies
  • Steve Roberts
    January 21, 2008 at 1:40 pm
    Make a black solid, then draw a rectangular mask on the solid.
    option 1: Keyframe the mask shape property, then scale and move the mask when you have to.
    option 2: keyframe the solid’s scale and position properties when you have to.
    option 3: keyframe the solid’s scale when you have to, but for position, track the shirt and apply the tracker to the solid’s position.
    option 4: apply the tracker to the solid’s position and rotation, then keyframe the mask’s shape when you have to.
    I’d do #4.
  • Edward Calabig
    January 21, 2008 at 7:34 pm
    Ok to do #4 do I just make the mask, then right click the source clip and hit track motion?
    If so, how do I apply it to the mask layer? Whenever I go to target and try to select the clip, it’s grayed out and I can’t target the mask layer.
    Is there a tutorial on here that shows how to do this? Thanks!
  • Steve Roberts
    January 21, 2008 at 8:05 pm
    Here’s what I just did:
    – import footage, add to comp
    – make black solid, mask it
    – select footage layer, open tracker controls
    – select motion source (footage)
    – hit “track motion”
    – target is automatically selected as black solid, but you might have to edit target
    – “analyze” the track
    – hit “apply”
    There should be more in the Help.
