Activity › Forums › Maxon Cinema 4D › How to place a null at the axis of one face in an object?
Posted by Craig Ricker on April 20, 2012 at 4:31 amThe main goal I have in mind is I’d like to use the axis data of this face to put a null. The face is the screen of a phone and i’d like to have a null there so I can render out the null position rotation information to send to after effects to attach a screen to there.
Any ideas how I do this?
Craig Ricker replied 14 years, 3 months ago 3 Members · 7 Replies -
Brian Jones
April 21, 2012 at 2:32 amI’m not an AE guy and you can do it with xpresso but I don’t think you need to, check out this https://greyscalegorilla.com/blog/2011/12/cinema-4d-to-after-effects-tutorial-plasma-tv/
David Biederbeck
April 22, 2012 at 6:59 amI’m not sure I understand why a compositing tag on the face of the phone with an object buffer does not work?
Craig Ricker
April 22, 2012 at 11:46 amDoes it provide position data to parent to in AE? In a tutorial I watched the dude used a null in the middle to get the position data and the object buffer just provided the matte?
Brian Jones
April 22, 2012 at 12:48 pmyes it does, check out the link, even though it’s a fairly long tutorial he gets to the bit useful to you fairly quickly
Craig Ricker
April 23, 2012 at 12:58 amOk watched that tutorial through and that looks like it would work. BUT…. my issue I’ve realised is this.
I have designed a phone, from a cube. And then I have gone and used the SPLIT tool to get the polygon face that represents the screen as a seperate object.
Now when i’m in polygon mode the axis shows itself as being in the direct center of that polygon. But if I click on MODEL MODE, the axis is at the center of the world (which is where I first modelled the phone from)
So how do I use the information that is in the bottom attribute display, when I have the polygon selected? Because it shows the actual location of that polygon in relation to the center of the world.
If I render out an external compositing tag as from that tutorial, it places the solid at the center of the world, as where the model axis of that object is?
I’ll post up a project file so you can see what I mean.
Brian Jones
April 23, 2012 at 4:00 amYou need to use Mesh/Axis Center/Axis Center… the other axis center commands (in the same Mesh menu) can get the axis in the right place but only the full command gives you the ability to not only put the axis in the right place but give it the correct alignment.
