Activity › Forums › Adobe Illustrator › How to pick up color from an image in Gradient Window?
  • How to pick up color from an image in Gradient Window?
    Posted by Sumeet Khurana on November 4, 2011 at 5:29 pm
    I am using Adobe Illustrator CS3on Window Xp.
    I have created a rectangle in my file and I want to put gradient to it.
    But I want to pick colors fom a reference jpg image.
    Double clicking the “gradient stop” only opens the color picker window and like Photoshop CS3 , Illustrator does not has eyedropper tool in color picker window.
    So is there a way in Illustrator to pick up a color from a jpg image in gradient window? I would be very thankful for any help.
    With kind regards,
    Sumeet.
    Manish Acharya replied 11 years, 4 months ago 4 Members · 5 Replies
  • Vincent Rosati
    November 4, 2011 at 5:36 pm
    I would just use the Eyedropper to select the color, them drag the color from your Color palette into your Swatches palette.
    Do this for both colors.
    Then create your gradient from your swatches.
    I don’t think this is exactly what you want to do, but it’s just how I might do it.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Sumeet Khurana
    November 4, 2011 at 8:59 pm
    Thanks Vince, but this is exactly what I have been doing all these days.I was wondering if there was some other way in Illustrator which could make my workflow faster much like in Photoshop.
    Thanks for the reply Venice.
  • Sumeet Khurana
    November 4, 2011 at 9:02 pm
    I apologise for the spelling mistake.
    Thanks Vince.
  • Les Nemeth
    November 6, 2011 at 1:45 am
    Select the eyedropper, select the gradient stop and hold Shift to pick color from the image into the gradient stop.
  • Manish Acharya
    May 20, 2015 at 11:08 am
    Awesome dude!!! Life saver.
