Activity Forums Adobe After Effects how to output a 16×9 widescreen qt movie from After Effects
  • how to output a 16×9 widescreen qt movie from After Effects
    Posted by Eric Holzapfel on May 24, 2009 at 3:35 am
    Hello There,
    I am trying to output a 16×9 widescreen movie from After Effects.
    I am using still images. My image size is 853×480 which is supposed to
    be equivalent to NTSC 16×9 widescreen, which is what I want. It is that size in the AE canvas. When I place it in the render queue, and render said movie, it come out (in FCP and QT) as 4:3. What am I missing? The comp settings appear to be correct (although 720×480). It says “widescreen” and “anamorphic” when I open the comp settings and check them.
    Eric
    Eric Holzapfel replied 17 years, 3 months ago 2 Members · 2 Replies
  • Simon Bonner
    May 24, 2009 at 7:33 pm
    Anamorphic refers to the say the picture is stretched from 4:3 to 16:9 aspect ratio, which might be why you are having problems.
    You need to know how you will be presenting your video. If it’s on a dvd or tv, it will need to be 720×480. If you are going to present it on the web or some other method of viewing on a computer screen and you want to preserve the 16:9 look, make sure you are using a preset with square pixels.
    Toggle the aspect ratio switch at the bottom of the Comp panel to see how the image is stretched with non-square pixel comp settings but not with square pixel settings.
    Simon Bonner
    youtube.com/simonsaysfx
  • Eric Holzapfel
    May 25, 2009 at 4:40 pm
    Hello Simon,
    I guess I should be “aware” of the difference you mention by now!!
    Thanks, I will check it out. I am planning to put it on a dvd/tv.
    eric
