Activity Forums Zaxwerks How to open a Scene file??
  • How to open a Scene file??
    Posted by Heimdall on August 9, 2005 at 8:03 pm
    Specs: Invigorator Pro 4 After Effects
    Mac OSX.3 Dual 2.5 GIG
    When I make a new comp, add a new Solid and access Invigorator via the Effects menu, I get a pop up screen that lets me:
    1) Create 3D Text
    2) Open AI file
    3) Create 3D Primitive
    4) Create a NEW Scene
    BUT I don’t have “Open Existing Scene” as the Manual states I should.
    How Can I open my scene files (import does not work).
    What a crappy situation. A lot of work down the drain, as I did not save it with the AE file.
    Which brings up another ranting question, why are you able to save a scene file, but not able to open it??
    -Heimdall
    Matt Rhodes replied 21 years, 1 month ago 2 Members · 1 Reply
  • Matt Rhodes
    August 9, 2005 at 9:07 pm
    Hi Heimdall.
    Since the scene data is embedded in your After Effects .aep file, you usually don’t have to save/load Invigorator scenes.
    However, for those wishing to load a saved Invigorator scene, you may use Cmd+O (Ctrl+O on Windows) when the 3D Invigorator Startup dialog is shown (the Startup dialog has the “Create 3D Text,” “Open Illustrator File,” etc. buttons).
    You’re correct in that you can save a scene while in the Invigorator Set-Up window, but you cannot currently open a scene there. This is a bug that will be fixed in the next version of the Invigorator.
    Let us know if you need more assistance.
    Matt Rhodes
    Zaxwerks, Inc.
