Activity › Forums › Adobe After Effects Expressions › How To Offset Start Frame of a Loop
  • How To Offset Start Frame of a Loop
    Posted by Mark Walczak on November 12, 2015 at 11:54 pm
    Hi Everyone,
    This seems like a very simple task, but I could use some help thinking through it.
    Basically, I have a clip of a 10 second loop that is being used three times in my comp. I would like to add some variety, and have each instance of the loop start at a different frame and loop seamlessly.
    When dealing with pre-rendered clips, I simply loop the clip in the interpolation settings and slide it in my timeline. When dealing with comps, however, things get a bit more complicated.
    My question is whether or not it’s possible to insert an expression into a layer’s time remapping attribute that allows you to simply slide the start frame of a loop and have it play out.
    Let me know if this isn’t making sense, and I’ll be happy to clarify.
    Thank you!
    https://vimeo.com/explosivegraffix
    Mark Walczak replied 10 years, 10 months ago 2 Members · 4 Replies
  • Dan Ebberts
    November 13, 2015 at 12:05 am
    Something like this maybe:
    s = Math.round(effect(“Slider Control”)(“Slider”)); // start frame
    f = timeToFrames(time);
    d = timeToFrames(source.duration);
    framesToTime((s+f)%d)
    Dan
  • Mark Walczak
    November 13, 2015 at 4:28 pm
    Dan,
    This is EXACTLY what I needed. Thank you so much!
    I follow your logic through the expression, but could you tell me what “%” does in the last line?
    Thank you!
  • Dan Ebberts
    November 13, 2015 at 5:33 pm
    % is the JavaScript modulus operator. It gives you the remainder of a division operation, so it’s what generates the looping value.
    Dan
  • Mark Walczak
    November 13, 2015 at 5:50 pm
